AJack
- Tampa 33621
- SX
Hopefully it will come with extended warranty and the premium mooring cover. My 2017 242SE came with that as a 'demo' last year.Hi all. I am thinking about pulling the trigger on a leftover 2018 AR240 with 4 hours on it. Being sold as "new" and out the door for $55,830 including taxes, registration, boat essentials.
How does this compare to your experiences?
Congrats!I'm finally picking up my demo boat next week. Did you also have issues with the anchor locker drain?
Yeah I figure. I'm just so stoked to finally get the boat that I'll be bummed if they have to keep her longer to fix the drain. Hopefully they noticed it and fixed it in her prior 6 hours of life.Congrats!
Fortunately, that defect is kind of apparent when you look inside the locker, if the anchor locket drain tube is not set up right I would just ask them to take care of it before you take possession.
At this price the dealer said he isn’t able to provide YES, I’ve asked, but I haven’t asked for a mooring cover or 10 hour service...yet. Will be sure to do that today.
What’s the deal with the anchor drain tube? What can I look for to see if it’s set up right or not?
Basically the the anchor drain insert in some cases doesn't extend all the way through the outer and inner hull and the outer and inner hull is not always sealed together inside that the hole that has been cut for the insert. This results in water dumping in between the outer and inner hull inside that cut hole. Couple examples:At this price the dealer said he isn’t able to provide YES, I’ve asked, but I haven’t asked for a mooring cover or 10 hour service...yet. Will be sure to do that today.
