haknslash
- Lake Martin, AL
- Moomba
- Other
I mentioned this in another thread but I didn't want to derail it any further. A problem with trying to delay convergence of a wave on our boats is that they simply don't sit low enough in the water on the non-listed side to allow for a wake shaper like a Ronix, Mission Delta or a suction-mount DIY wake shaper to work. There isn't enough side hull or surface area below the waterline not to mention the issue with graphics being porous so suction cups wouldn't hold. So I was wanting to come up with a way to have a surf gate similar to the Malibu surf gate design only this method would be using the two rear tie down strap tow points to lock in a tie bar, sort of like COtoFLSurf's rubber jet wash mat .
So here's my rough photoshop of the design...
And here is mock-up CAD design. it's all early right now in the design but I will run FEA stress analysis to ensure a design can be strong enough. I have CFD flow analysis software too but without an exact 3D model of a Yamaha hull this data wouldn't help much so I will just have to make a few prototypes at various angles. There is a common using of angles from an extensive DIY wedge thread on the mastercraft boat forums to give me an idea of what may get me in the ballpark.
And then here's a more traditional Malibu style with an actuator. It's basically a trim tab on its side. Actuator stroke would need to be long to allow 90° rotation. Obviously this would make the cost much higher as you would need to buy actuator(s). but what if it was manually done and you had locking positional pins instead? cost would come way back down then but of course would lose the nice electronic/remote aspect.
Thoughts?
Thoughts?
