Do I need a wear ring replacement?
shadynasty
Scarab
195 ID
Hey everybody. First time poster but long time lurker.
My lovely wife accidentally got a little too close to the shore after dropping me at the dock, panicked, throttled up and gave our Scarab 195 250HP impeller a healthy bite of the sandy bottom. It was like hearing a jar of marbles dumped into a blender.
After letting it rest for a good while, I took it out to assess the damage and could not throttle above 3,000 rpms without the boat violently shaking. Like terribly.
From there, I idled to the dock and trailered it home.
Today I removed the bucket and jet assembly today to remove a visibly stuck rock and checked out the wear ring. There is a significant channel dug into it.
Do I need to replace this ring? I’ve never had an issue before this.
Luc Lafreniere
Scarab Forum Lead
Ottawa, Canada
Scarab
165 G
That's definitely a good groove. But the question is whether it causes loss of pump pressure or cavitation. Before replacing it for no reason, I'd simply put it back in and test your top speed. See if you notice any loss of speed/power. You may be lucky.
But otherwise, yeah, they aren't expensive to replace especially if you're doing it yourself. You can always keep this one as a spare one in case and put a new one in. But I'd still test this one so you know.
There is a gap in the manual. Here's the pic:
shadynasty
Scarab
195 ID
That’s a good idea. I even considered buying two to keep one on hand. Haha.
To be honest, I am not experienced with this and wouldn’t know cavitation unless it was severe. Do I just keep an eye on speed to notice a slight difference?
The nearest scarab dealer is an hour from me, and of course they suggested that I bring it to them for the replacement. Or I can buy a 161mm wear ring from the place down the street and roll the dice.
Luc Lafreniere
Scarab Forum Lead
Ottawa, Canada
Scarab
165 G
You already have the pump out. There are tons of videos on how to do this. I'd suggest you do it yourself. If for some reason you encounter an issue, you can always bring it to them.
But yeah, cavitation = loss of power. Just go from 0 to 100% from a stop and see how it performs. Go to top speed and see it it reaches your top speed. That's pretty much it. If you have lost a few mph... it can still be a backup ring in case you ever need one to hold you over. I keep a spare ring... but I've never had to replace mine. So it's not as funny as you think it is! lol I just don't want to have to wait around for parts when I could have one on hand for relatively cheap.
shadynasty
Scarab
195 ID
Great advice.
There are a few chips in the impeller. Any experience there?
Some of the instructional videos I have seen really scrutinize even the slightest nicks.
Luc Lafreniere
Scarab Forum Lead
Ottawa, Canada
Scarab
165 G
It all adds up eventually to loss of performance. The more nicks in the impeller, the more grooves, the more space, etc. But those seem fairly small. I don't expect any significant issues. I'd take it off and simply use a file to smooth out the edges all around.
The gap between the impeller and ring is much more important. But you could be lucky all around here. No way to know until you test it out.
WaTeRMaNiaC407
Orlando, FL
212XD
If you replace the wear ring and still have cavitation then it is likely your impeller is damaged. You can send to IMPROS and they will repair it for much less than it would cost you for a new one. I have used them several times with great results.
AZMark
Phoenix, AZ
Great profile name!
DavidScarab
Scarab
HO Impulse
DavidScarab
Scarab
HO Impulse
Same thing just happened to me yesterday with my scarab. Heard the marbles then it just stopped. Now when I try to start it it turns over very slowly. Wondering if the wear ring or impeller are just stuck or something worse. Any thoughts.
