BigRay242
- Northern California
- Limited S
- Removed
Ok. Good luck.That's my boat, but it's not in Utah. The boat is in California. I had put it up for sale at one point. Perhaps this is from that? See tags and license plate below.
I'm not looking to sell it. Just want to get it back in the water.
Thank you for all the advice. Here I was... gearing up for some major maintenance before I even started it. I'm going to swap the batteries out with new ones. The service manual says "Marine Grade Group 24 Dual Purpose 675 Marine Cranking Amp" but that was one battery, and I had that swapped with these two. When I get to the boat, I'll try to figure out the type and cranking amps (I think 690 each).
I'll check the gas smell as well. What additive do you suggest before starting?
I'll pull the plugs. They are brand new 2 years ago. It hasn't been in the water, but don't want them to get stuck so I'll pull them if not just to have a spare.
I did find this Maintenance Interval Chart from the Service Manual.
FYI your boat pics have been used by scammers on Craiglist for about the last 6 months or more. I have seen it listed in Cincinnati, Detroit, Columbus and other cities.That's my boat, but it's not in Utah. The boat is in California. I had put it up for sale at one point. Perhaps this is from that? See tags and license plate below.
Hmmm... Maybe it was not sitting for as long as he thought. Bet they put some hours on it getting it around to all of those places! (hehehehehe)FYI your boat pics have been used by scammers on Craiglist for about the last 6 months or more. I have seen it listed in Cincinnati, Detroit, Columbus and other cities.
Can you share some of the rationale and thoughts describing the benefits?There are a lot of reasons you should religiously drain your fuel tank from time to time. To cut costs, you can do it yourself effectively. This procedure will reduce your costs on professional fees and cut the budget on repairs if your fuel tank is at risk for potential damage.
