scokill
- Rowlett, TX
I used some simple green/purple power sprayed everywhere and a pressure washer.. Looked like new..
Spray it down, let it soak and then hit it with a hose or pressure washer. Just like any engine dont hold the stream of water on electronic connections for any length of time.. just a sweeping motion is fine. I like the pressure washer cause it doesnt put as much water in a direct stream I use the Fan setting about 12" wide 12" from the tip..
Simple green for me too!
