Electrical
FloJet
Moore, Oklahoma
@HELP Do the 2016 ar240 have fuses to the house electrical. For some reason when I switch my house batteries on, nothing comes on. Can't even get the blower to turn on. I'm thinking I blew a fuse somewhere? But not sure where that is located. Any help would be greatly appreciated.
I don't know.
I would think there was a in line fuse holder near the batteries.
Have you done anything with the batteries lately?
When was the last time it was working correctly?
FloJet
Moore, Oklahoma
Last month when I took it out. I added two more batteries but that's irrelevant I think cause I hooked the electronics to my one 12v starting battery and still nothing is happening. Very strange. With all my mods lately I wonder what I did lol.
Gym
Falmouth, MA (Cape Cod)
@FloJet. If it's the same as the older boats the fuse for the house ckts is on the rear wall near the battery. Have you reconnected your batteries recently. Possible reversed connection.
FloJet
Moore, Oklahoma
Ya looks like the connections are correct. Even tried different batteries. So strange. Tested all batteries n they r all good too. Has to be a fuse somewhere but I do not see where one could be
Neutron
New Bern, NC
Here ya go its above and behind the engines,
Neutron
New Bern, NC
Most likely #5
robert843
Myrtle Beach, SC
If its not #5 check your ground maybe the cable is not tight from when you were adding batteries.
FloJet
Moore, Oklahoma
So I found the blown fuse. There are 2 (20amp) fuses in the box next to the battery switches. One of them had been blown. Can't believe I kept overlooking that little box. Thanks for all your help guys. Now I have to figure out why my WS equalizer is getting constant power when the switch is on the off position and it's connected to a relay. lol. All this re arrange and re doing crap is getting to me now.
Glad you found it! Was it the big blade fuse holder on the bulkhead/wall?
FloJet
Moore, Oklahoma
Thanks. It was actually the mini blade fuse.
JetBoatPilot
Event Sponsor
Event Sponsor
Panama City, Fl
Glad you got this handled. I am not much help in electrical matters.
Cobra Jet Steering LLC
One thing you need to remember, if you just reverse a connection for a split second it will blow out that fuse and that may have been what you did somewhere along the line of adding the batteries etc.
Yep.
And don't EVER connect a bilge pump in reverse (polarity).
tdonoughue
The Woodlands, TX 77381
Nor a ballast pump.
Jimmers
55802 Duluth, Mn
I had a similar problem several years ago, blower didn’t work along with a couple of other things. I checked all the fuses and they were fine. I finally crawled under the dashboard. I found that the wiring harness junction had become disconnected. Reconnected them and everything works fine! Good luck.
