WilCo
2013 AR190
Impeller replaced in 2017 shortly after purchasing.
Engine replaced 2018 (timing chain break) with new engine from Yamaha
Boat has been run pretty consistently 1-2 times/week last 2 months or so (thank you Texas weather).
~1 month ago, started noticing that engine was missing a bit around 6500 rpm, which happens to be about the throttle that gives the best wakeboard and kneeboard towing speed for my kids -- so it's used regularly.
Even though I replace the spark plugs annually, I did them again just to be sure (see lengthy other thread about incorrectly gapped plugs, stuck plugs, etc which was reviewed by a mechanic)
Tested after spark plug change and had same engine miss around 6500 rpm as before.
Air filter is clean - no evidence of oil on it so don't think I have overfilled.
Added 2 cans of SeaFoam Marine Pro to my 3/4 full of fuel boat before we got on the water yesterday. Ran for a few hours without any noticeable issue. Was starting to think perhaps the SeaFoam and fresh plugs had worked together to clear any issue. Then engine started bogging down pretty bad while towing the tube. Pulled the tube in and ran WOT for a bit (while headed towards the dock just in case) to see how it sounded. It didn't seem to get much better (at times would struggle a bit and other times sounded good).
Finally decided to put it back on the trailer. Made a video at WOT while focused on the tach. It stayed at 7000 rpm for the first 6 seconds of the video before shooting up to about 7600 for the final 5 seconds of the video. Top speed was 24 mph per the digital speedometer, much lower than normal.
Pulled the impeller and there is some definite leading edge damage and wear ring damage that I need to take care of, but I don't think it fully explains the engine fluctuation. Fellow member @tdonoughue has offered to hook it up to the YDS so will do that when our schedules mesh, but open to any other ideas you may have as well. What else should I check?
