- Corinth, TX (DFW)
@txav8r Yes it is at the Lakeview Marina. As of this moment I would say 95% of the marina parking area is underwater. What they have done is linked most of the docks together with temporary walkways starting from the sailboat docks at the base of the marina. They are also running a courtesy shuttle via pontoon boat to anyone who doesn't want to haul all of their gear through the maze of linked docks. At this point I think the only issue this coming weekend will be parking, but I'm sure we will figure it out. The gas doc is also cutoff by high water, so the guys that run the gas dock must access the dock via boat as well.@jawsf16 , is that North Island in the middle of the lake, only showing some tree tops?
@BigN8 , you keep your boat in a boathouse don't you? Ramps closed at Lewisville? If you can get to your boat you can use it? I am wondering if they will let you access your boat in a boathouse when you have to almost swim to it.
