swatski
- North Caldwell, NJ
(EDIT: Also check post #7 below for further improvements/intake port upgrade)
Three (3) is better than one (1), right?
AIM:
To fill the large custom Transom Bag (TB) faster (FatSac with small 3/4" diameter ports) - in order to match fast filling times of Center Locker (CL) bag (w/1" ports).
APPROACH:
Re-route/cannibalize integrated ballast plumbing to fill TB through three (3) ports using three (3) reversible pumps / three (3) intakes, leaving CL plumbed as is (w/one dedicated pump/intake)
BACKGROUND:
My Center Locker (CL) and Rear Locker (RL) bags are all SUMO w/1" ports and those fill fast.
The FatSac Transom Bag (TB) is great but for it's large size (~900lbs) its 3/4" diameter ports are just not ideal.
We currently typically only fill TB and CL for our wake surfing sessions, so the two RL bags do not get much use.
Our custom WakeMaker system operates with 4 independent reversible pumps drawing form 4 independent intakes.
Pumps are installed in wet storage lockers int eh transom, and serve also as valves; since there are no other valves/splitters etc., the RL and CL bags fill fast (1" diameter throughput except the pump itself) but the TL bag lags behind (a lot).
Here is the reworked TB fill system:
(green arrow points the original fill/drain port, the red arrows are the additional ports - 3 pumps/intake filling one bag! The forth port is an Air Vent)
Center Locker (CL) - no changes:
For the record - here are the intakes (over the Articulating Keel - rudder) - one each to CL, RLs, and one AUX (auxiliary - to TB):
And pumps (in wet storage compartments, two on each side - not yet fully installed/wired in the pic)
TB is stored in the PORT side wet locker:
Additional plumbing lines are int eh STRBD locker:
Pull those out and set the bag/plumbing lines for fill-up, less than a minute:
Start filling the TB and the CL bags (engines ON in "No Wake 3" ~2,000 RPM to keep the voltage up at ~14v):
CL is now slower than TB!!
(about 1/2 full)
The TB is full!
We are done setting up to surf in UNDER 5MIN!!!
Who needs RAMFILL??!! lol
To drain, I just disconnect the two bottom Quick Connect ports of the TB and let it run, use CL pump to drain - all while heading back to the docks.
AIM:
APPROACH:
BACKGROUND:
(about 1/2 full)
The TB is full!
