ralphsmithiii
 - Tampa, FL
I completed my first attempt at building a simple fresh water/wash down tank that's main purpose is to hopefully reduce my boat cleaning time at the end of my trips. Currently, I pull the boat out, take it to dry storage and spend an hour or so cleaning it. Then it needs to sometimes sit a day uncovered to dry which mean I go back the next day and cover it.  That's not a huge deal as the storage is 1 mile from my home.
However...
I thought if I could take the boat out and while the salt water is still "fresh" (if that's a thing) and clean the boat at the docks, I could tackle that problem plus it'll be dry on the 30-45 minutes trip back to storage. I could then save a ton of time plus an extra trip to cover it.
During black friday I picked up a 4.0gpm/60psi wash down kit from West Marine for 50% off (199 down to $99). I bought a 16 gallon tank from Northern Tools (similar tank used by The Spray Kit). Bought a few feet of 3/4 hose based on the pump nozzle sizes and a 10ft 12v cig lighter cable to power it. It's not 100% complete but so far it looks promising.
What I'm looking input on is the hosing. I'm not 100% sure if the way I have it done is "optimum" for water pressure. I'd like a cleaner look with more elbows and such. The pressure is decent and I think it'll suit my needs OK. However, the nerd is me is wondering am I losing out because of using the 3/4 hose. Should there be a hard line directly into the tank versus drilling the existing hole bigger and showing a hose down into the tank, etc.. etc. I opted for the 4.0 gpm over the 3 and 5.0 gpm due to suggestions. When I think about washign down a 24ft AR240 I think, no way can 16 gallons do that. However, with a foam cannon and boat soap, some Salt Away, a wash mitt and brush AND being just right out of the water, I think 16 gallons will do the ticket. Worst case I can transfer everything to a bigger tank.
Please let me know if there's a better/more efficicent way to route the inlet hose. Again, its not sexy and I'll clean it up but it does the trick. Just really wondering if I can squeeze a little more pressure if I change up the 25ft supplied blue coil hose and/or change up the inlet into the tank hoses.
			However...
