For those who live at the lake with your own dock/slip...
johnkim
Few questions for those that live next to a lake with your own dock/slip:
1. Do you keep your own in water during the entire season?
2. After each boat use, do you put the cover on?
gallobg
MasterCraft
Yes and yes. I keep it in the water for convenience, and keep the cover on to protect from the weather, bugs, and birds.
I do pull the boat every month to clean the algae off the hull. This year I’ll have a lift so hopefully can avoid that.
Dave burke
Near Lake Placid
Yes and no. Unless the boat’s not going to get used for a few days, I don’t put the cover on.
While the boat is in the water (typically may-oct) and particularly in July and august, we use the boat almost everyday so I don’t put the cover on.
Not saying this is right or wrong but it’s worked ok for me.
BJSelzer
I leave the boat on the lift year round because we have a covered slip. I dont have a garage it would fit in at the lake, so I'd have to pay for storage or expose it to the sun if I put it on the trailer.
The lake is a bit over 60 miles away from our house so we typically only go down for weekends and I pull the mooring cover off when we arrive and put it back on when we leave. I do get the boat all the way out of the water (on the lift) anytime we aren't out on it to avoid waves knocking it around in the slip.
captras
Lake Livingston, Texas
I have a lift and never leave the boat in the water. Even if going back out later that day, the boat comes out of the water. When we are there for the weekend or several days, the cover is left off till we leave. The boat is, however on the lift, is under cover in the boathouse.
bumpy
Ashburnham, MA 01430
Cobalt
I have always (more than 25 years) left our boats in the water at our dock for the whole April-October season except when we went for a week or two to a bigger lake or the ocean. I've always regretted not covering when I neglected the chore!
Billtex2000
Lake Wallenpaupack, PA
Yes, in the water, and cover goes on unless we're using it for a few days in a row, or overnight rain is in the forecast.
rrmidden
Boat stays on the Lift from April/May to October. Even though the Lift has a Canopy Cover, we still cover it every night, helps keep birds, bugs, dew, etc. out of the boat.
Canuckjetboater
SX195
@johnkim ..... leave the boat in water May to October. Have separate snap-on bow and cockpit covers (OEM Yamaha). 5 minutes off and 5 minutes on keeps out bird $hit, critters, mildew etc. Wash hull at beach or sand bar every 10 days or so and pull once a summer for more thorough clean. :cool:
thefortunes
Exactly the same here.
biffdotorg
Pelican Rapids, MN
Yes, in the water, but on a lift. So really no different than being on a trailer. We have a canopy, so the sun doesn't bake it too badly if I choose not to cover it every day.
Like most say, I leave it uncovered if we plan on going out within 24hrs. Otherwise, it gets the snap on covers. It keeps dirt, leaves and birds out of the boat.
When I pull it to trailer, I use the black mooring cover to protect it as well. Plugs are pulled and spray lubed weekly. Onboard dual bank charger gets plugged in every other week or so. I monitor the voltage.
mdem37
For you guys that leave them in the water - I thought you weren't supposed to leave jet boats in the water since it's bad for the seals or something?
johnkim
Curious to hear what you guys say about this...
mark_m
Columbus, OH
No issues with staying in the water, other than the scum on the hull that accumulates. Oxalic acid solution cuts right thru it. Just pull it and clean it a few times to keep it manageable at the end of season when you put it away for winter.
QuakeTen
AR195
I leave mine in the water from May to Labor Day. If I use the boat during the day, I leave it uncovered for a few hours when I get home to dry out. I always have the snap on bow/ cockpit cover on overnight. I never go without it.
My lake doesn’t allow lifts or covered docks.
Huv1
Central Maine
I leave mine in the water the entire season. Never had an issue. I cover it when I know it might not be used for a few days or if there is rain in the forecast. Some years I pull it half way through the summer to clean the hull but not always.
mdem37
I'm guessing you all are leaving them in freshwater and not saltwater?
DonnyC
Granbury, TX
255XD
1. No. Have a covered dock with a lift, so always pull it out of the water when not in use.
2. Put the cover on if we're not going to use it the next day. So it's covered most of the time.
Sold our 2010 in Sep. that was in excellent shape; interior almost perfect. 2021 is on order.
Billtex2000
