Akwoolf
- Michigan
- FSH Deluxe
Edit: Issue Resolved. Read through the thread if you are running into a similar issue.
Hey guys-
2016 FSH that turns over, but won't start...
* Behavior seems to be the same as when the lanyard/cut-off is pulled. (It is in!)
* Checked connections behind the console and everything looks good.
* Battery strength is good. All connections tight.
* All accessories operate as they should.
* Pulled spark plugs and they don't appear to be fouled.
* Motor has less than 50 hours.
* Checked fuse block in engine compartment. All fuses look good. (Edited for prosperity: Originally the boat would not crank at all. The main fuse was blown and replaced recently. After that, the boat was able to crank, but not start)
* Filled tank with fresh fuel after pulling out of storage for the winter.
* One other thing that seems a bit odd, but not sure - the RPM gauge is stuck on 8. Doesn't move. I seemed to remember that it would rotate back and forth, but that may be after it is started
Thinking about the whole internal combustion thing, I think about spark, fuel, and air.
Could this be an issue with fuel? I am not sure where/if there is a fuel filter to check. Even when turning it over for 15-20 seconds, I don't really smell gas. If I knew of a place to spray starter fluid, I would even try that. (haa)
My gut tells me that I am missing something simple, but I am not sure. I have lurked in this forum for the past few years and have been able to find some really good information and tips, so after spending the last few nights double and triple checking what seems obvious, here I am...
Hey guys-
(I'll do some more searching until I hear from one of the knowledgeable members here.)
