FSH in the rain
dlkhmk
FSH Deluxe
Like many others on here I have sealed and repaired every thru hull on this boat. I finally have a dry boat when on the water.
My FSH is always stored in a garage, so until last night it has never seen any significant rain. Well I left her in the driveway last night after a day of fishing with a plan to go again today. We had a pretty heavy thunderstorm last night and now I have a good gallon or more of water in the boat. All the hatches were closed, rod holder caps were on, and the center console covered.
Anyone have an idea how and where the rain is making its way into the hull off the boat?And most important how to stop it?
highanddryinco
Denver, CO
FSH Deluxe
I'm assuming you re-sealed the deck drains at the thru-deck and not just at the thru-hull?
dlkhmk
FSH Deluxe
Deck drains are sealed too. I'm wondering if the rod holders need sealed as well.
highanddryinco
Denver, CO
FSH Deluxe
I figured you probably did. That would have been the easy answer.
Rod holders wouldn't hurt.
I haven't sealed mine yet but I would suspect the access cover in the deck floor over the fuel tank is probably a big leaker too.
JDinfla
Rod holders take on rain.
Also those cleat assemblies are not waterproof, will leak water especially if left extended/open.
Hannibal
I've wondered about the gas tank hatch too. Mine takes on some water in a heavy rain if I don't have the cover on.
highanddryinco
Denver, CO
FSH Deluxe
I went ahead and did mine on Sunday. Looked about as bad as the other thread where the guys were re-sealing the hatch in wet compartment. I took out the screws and the hatch lifted off the deck with zero adhesion. The little bit silicone they did use stuck to the deck side. Unfortunately all I had left was more silicone so I goobered it full and bedded the hatch back into it. I'm certain it had to be leaking substantially.
Fingers crossed for a decent seal. I am not a fan of crappy silicone where plastics are used. My big tube of Life Seal got here Tuesday so I'll keep up with my other sealing projects.
Van T
Chesapeake va
Everyone does realize these are boats shit can get wet tilt it and drain they would not have put drain plugs in otherwise
JDinfla
Yeah... nobody on here probably knew that.
Van T
Chesapeake va
Just joking but I know these do let on to much water I wouldn't ever leave mine in a boat slip it would be under water first night
Grover70
Ponte Vedra, FL
FSH Deluxe
I came back with a dry FSH from a few hours on the river. There was some splashing on to the boat, but nothing in the bilge or the changing room. Took it home, washed it down real good and wham! Water in the changing room, a little in the bilge. It figures too. Those drain areas along the front storage compartments, the rear seats, the engine compartment, the Deluxe seat port, etc. can only hold so much water before it overflows. The capture the water, but don't drain out. Especially along the jump seats next to the tower. So, in a rain I would expect the water to overflow into the bilge/changing room, no matter how tight or siliconed everything is.
dlkhmk
FSH Deluxe
I concur. All the repairs and sealing have been great at obtaining a dry boat while on the water. Especially the anchor drain fix. I think the only way to solve the water intrusion during heavy rain is either a garage or a cover.
Tonkatoy
Glendale, AZ
FSH Deluxe
I think if we were all told how our boat boat was supposed to work (wet storage, dry storage, which plugs to leave open), we would have realistic expectations for how our boats are supposed to work.
Manual says nothing, dealers don't have straight answers on these issues. (At least the 2 dealers I have dealt with didn't)
A YouTube video from Yamaha would be nice.
Do you hear me Yamaha?
Yes, I'm thinking this changing room is part of the bilge and that's it. Got to leave that plug out and not leave anything on the floor that you don't want to get wet.
I think we assume it's dry storage, but it is not. Wishful thinking I guess...
I'm not letting Yamaha off the hook just yet, they still has some serious sealant issues to sort out. I've had more fittings leak than not.
Earfixr
Mississippi-Louisiana-Alabama Gulf Coast
In Yamaha's denfense, nothing in print about the FSH uses the words DRY and Storage next to each other. During my shopping phase, other boats that cost 1.5-2X higher had "real" dry storage in "real" lockers. Am I surprised the head compartment gets wet? Not really but I never assumed it would be dry. In 30 years of sail and power boating I've never seen any compartment that shares air (and water ) with the bilge to be drier than a popcorn fart, and nor would I expect it to. It has a drain plug in the bottom for a reason. Dry bags are your friend.
Evil Sports
91 North/75 South
SS
Well when you buy a boat you dont expect it to fill up with water in every compartment or worry about it sinking
Grover70
Ponte Vedra, FL
FSH Deluxe
I don't think anyone said either of those things did they?
This type of thread seems pretty popular and Earfixr is right. Anytime I've seen a boat sitting in the rain it's going to get water into the bilge. Or maybe into some compartments if it's not covered or, like my FSH, the gutters around the seats overflow with water.
Last time I checked, boats were made to get wet, drain, and go on their merry way!
