Markk
- Grand Prairie 75054
- Limited S
Worked on one of our older commercial vehicles today. Replaced the spark plugs, wires and coil packs.
My question is related to reading the plugs I pulled out. Plugs from driver side collectively looked very different than passenger side. Also notable, plugs from passenger site on cylinders 6 and 8 smelled of gas.
With the plug groups looking so different I’m concerned I may have a problem prior to the coil packs. If only 1-2 would have been different I’d have dismissed it as just a bad wire or coil pack.
The truck ran much better after new parts. Only concern is that it stumbles occasionally when applying gas quick from stop. After takeoff engine runs very strong and smooth. I’m considering replacing alternator, based on hunch that it may be losing current at low idle. Seems to stumble more when all lights and AC are on.
Engine is 15 years old with 97,000 miles. I’d welcome any insight or suggestions for what other parts to check out. I plan to pull a new plug from each side in about 1000miles to see if there is any notable difference.
