Hello from Texas
captras
Lake Livingston, Texas
Yea we have been up that way in skis..just not the boat. I do have a Garmin GPS with a map that actually allows you to follow the river itself. Just haven't been able to convince the wife that we can trust it
boudin
Well, back at it finally this weekend. With all the holiday parties and work I have not been able to get up to the lake lately to work on the boat.
I was able to install a new stainless scupper with an aluminum backing plate. I used 3M 5200 on the backing plate and around the scupper lip. The temperature dropped here in Texas to the 40s-50s, so it'll take a few days for the 5200 to cure.
I was also able to pull the cleanout plugs using my cherry picker. They came right out. I cleaned them up and then rebuilt the lower part using new Yamaha kits. I also added drilled a hole and put in pins to prevent any premature releases.
I have new pump nozzles, so I should be able to get those in today, as well as straighten out the bent reverse cable on the port motor.
Next is a new deck fitting the the top part of the scupper drain (my old one broke when removing the hose), and then I'll put the scupper hose back in (I have all the parts). I also need to do a couple of more oil changes as the oil is still a bit milky in both motors.
I'm shooting for a water test by New Years Eve.
-Greg
Livewire
Troy, AL
Limited
Nice work! Looks like you used regular cotter pins in your clean outs. I assume they go all the way through. Looks like it might be tedious to remove once installed.
boudin
Yes, I came to that conclusion once I installed the plugs. I'm thinking now of a piece of 12ga copper wire should do the trick.
-Greg
captras
-Greg
Looks good. ..lots of work but you will have a great boat for a good price when is all done! Hope to see you on the water next summer!
swatski
North Caldwell, NJ
-Greg
Very nice work!
It’s been a while now since my last major project, I’m feeling the itch!
As far as the plugs - I would recommend going strait to Cobras EZ locks, you will never look back. With the Christmas discounts those must be like a whooping $10 or so in Jeff’s store. :)
boudin
Back on it today. Did a good cleaning and thought I would be able to put her in the water. She looks real pretty now inside. A lot of silt washed down through the boat into the bilge. I'll let that dry and then vacuum out the silt/sand.
I was able to get all the #4 square head bolts off the fuel tank deck cover, with only one that was troublesome. A few whacks with an impact driver and was able to get it out. Then was able to remove the lid, and install a new deck scupper fitting (my old one was broken). It also allowed me to power wash the top side of the fuel tank and area around it.
#4 drivers on Amazon: https://www.amazon.com/gp/product/B00A8QGXAM
I had a lot of problems getting the scupper hose onto the new stainless rear scupper fitting. I tried soap, teflon spray, heat, to no avail. It's frustrating as that area is tough to reach your arm in and push on. The hose is just a little too tight for the new stainless fitting.
I'm going to order a muffler pipe expander and enlarge the scupper hose a little bit. Hopefully that will do the trick.
https://www.amazon.com/VETOMILE-Expander-Exhaust-Muffler-Spreader/dp/B0736RJZCL
-Greg
Scottintexas
Corinth, TX (DFW)
It is tough sometimes to get the hose back on the scupper.
We had a member pull the hose out thru the open scupper hole and attach it to the valve with the scupper nut still inside the boat and then slip it all back into the boat and then apply the sealant and tighten the nut up,
boudin
Yes, I came to that conclusion myself. Unfortunately I used 5200 to seal up the new scupper, so I don't want remove it again. I've ordered the pipe expander--pretty sure that will do the trick.
-Greg
boudin
Just a quick update... I snapped the end of the starboard steering cable when attempting to straighten it. I ordered a new one from SBT, as well as a new port reverse cable. I am an SBT dealer, so I get a pretty good discount. I think I paid $181 for the set with free shipping. I bought one of the Lowes Kobalt Pass-thru socket sets to unfasten the steering cable. (I never miss the opportunity to buy new tools--can't believe I don't have one of these sets already.)
I also went ahead and ordered a new transducer and speedometer pickup (both were damaged--I had hoped to find ones used, but could not).
Also, yesterday I attended the Houston Boat Show. We checked out the new 2018 Yamaha jet boats. As we sat in a 242 Limited E Series, my wife looked at me and said "Wow, these are really nice." Ha! I reminded her how the boat house we built last year was sized for a 26' boat.
-Greg
Txjetter17
Galveston, TX
It always happens at the boat shows. We live in Galveston but we go up to trinity a lot in the summer and hang out around the island and go up the river.
boudin
Finally was able to water test and put her in the lift yesterday!
A summary:
  • New steering cables on both sides
  • New port reverse cable
  • New reverse buckets
  • New OEM depth finder transducer
  • New OEM speedometer pickup
  • New stainless scupper and new deck scupper fitting
  • 5x oil changes on each motor; 2x filter change
  • New spark plugs on each motor
  • New battery and battery cutoff
  • Rebuilt jet pump cleanout plugs with new OEM kits
  • (4) new Polk Audio DB651s speakers
  • Fixed the front anchor/swim ladder hatch hinges
  • Whole boat power wash and cleaning
Next:
  • Yamaha cover (anyone have a used one?)
  • New traction mats throughout
  • Have fun!
-Greg
boudin
Just ordered an OEM cover from partzilla.com. $546.46 w/free shipping. That's the cheapest price I could find.
MAR-210MC-TW-CH
06~11 210 SERIES W/T
-Greg
Austin1
Nice to see some fellow Livingston folks. I’ve always frequented lake Sam Rayburn but now I’m in Livingston and just bought a SX210. Any areas I should avoid on Lake Livingston? Any must see spots?
boudin
Most of the lake is flooded timber, and yes, caution in some areas. It's a big lake. I would suggest talking to a local, and also looking at a map.
I know the White Rock area well--upper Lake Livingston. If you want info about that area, let me know.
-Greg
boudin
A few pics and video from our test run this past weekend, about 40 miles round trip. My buddy is driving, and absolutely loves the AR210. Notice tachs at 8k and speedo... pushing a little further, we were able to consistently maintain 44 mph at 8500 RPM.
-Greg
Livewire
Troy, AL
Limited
I'm surprised the depth gauge is working at that speed. Great work thus far!
tdonoughue
The Woodlands, TX 77381
I am out there at least once a season. We have friends who have a house on an ox bow of the Trinity, so we run the Trinity to the very north side of the lake. The lake is HUGE. We usually hole up in an alcove somewhere and float. Lots of shallow 3'-ish places where you can just float and relax. Do watch for those logs, though. One bit my boat a couple of years back, which is where I learned many of my fiberglass skills...
That said, I am usually on Conroe. If you are going to be in the neighborhood, drop me a note.
boudin
Slowly making some improvements... I realized last Friday that I needed some help pulling into my boat house in moderate chop... boy was that a challenge. Way easier with the old stern drive. After some research, I just ordered a set of JBP Thrust Vectors and will put them on next weekend.
I'm not quite ready for SeaDek, so I picked-up a set of of very clean carpet from a fellow member. Thanks @jcsmith77, they look great!
-Greg
