Big Shasta
- Panama City Beach, FL
- Boatless
- NA
- Other
- NA
I believe the oil on the bolts helps you achieve the proper torque and the MolyB on the cams probably assumes you are doing some sort of break in of new parts. Do you need it in this application? Probably not, you didn't remove the cams right? (or did you have to for head removal?)Anyone worked on heads- do you use 2 stroke oil on bolts like manual says - and molybnium disulfide grease on cams? Seems like the whole area is bathed in engine oil when run...
Looking at the pictures, with that much of the wear surfaces "unmated" I'd probably use the cam lube, there will always be some slight alignment difference that might cause some new wear on first start up. the cam lube helps lessen that.
