subysti
- Enfield CT
I hope these aren't interference engines or you may need more than just fixing the timing.
Now that you have started to breakdown the engine it might be to late to check but did you add a few drops of oil and recheck the compression, see the bottom of the table that @Scottintexas posted. Depending on what the compression does with a little bit of added oil will give you a place to look for the cause.this is a screen shot from the maintenance manual, do you mean the engine, oil, temp lights, 3 on each tach ?
