CrankyGypsy
- Tampa, FL 33615
- SeaDoo
- Challenger
weak spark: if it is indeed weak, that would mean there is something somewhere causing the signal to bleed off, right? either grounding away or causing resistance. if it is resistance, something is going to heat up. @andyak what is the "bypass motor" you referred to earlier that was overheating?
