andyak
I saw spark In the light. Plugs were not grounded well just sitting on block - when one rolled to side I even got spark between engine and metal insert in plug coil where bolt holds it down- as it was closer to ground at that point.
Toward the end I checked spark on working engine and it seemed comparable.
Working engine sounds different when cranks( starts really fast too)
Bad engine seems to crank fast and whine more. Which makes sense if compression compromised.
Back when testing, I put some seafoam Ina and cranked without plugs and it all blew out- so I could tell valves were cycling. Then I put in a little Lucas oil in each cylindar to help compression- you know the story - still no startup.
