2nazt
- Port St. Lucie, FL
- Tidewater
- Other
I would double check the fuses again as Cam stated also. If you have your blower on and turn the key does the blower slow down at all? If it does the system is at least pulling power if not it is not getting power past the key switch. So it could be faulty wiring or maybe a throttle position indicator on that motor for neutral maybe. I know the Yamaha connectors a pin can come loose at times anywhere and sometimes unplugging and plugging back in helps. Or someone with YDS around could help.
