Kevin107
- Frisco, TX
Followed davel510 post I was able to get power from the engine power wire. The problem is with the sense wire on the dvsr. I cut the cable but there are still power on the dvsr. Both end of the cut wire has voltage. Since the switch is off. Only 1 end of the wire should have voltage right?
Im so confused right now.
