Mainah
- Chapin, SC
- Boatless
- NA
- Other
- Other
The bigger issue with going the disconnect route is actually remembering to reconnect. Your house battery will not receive a charge from the engines running if you forget to reconnect. Adding a switch would be a bit better but you still have to remember. I like the engine on wire method because it is automatic and human proof once properly connected.
