Hero or Zero?......"Resealed" my Jet Pump
jEt_jAk
SoCal
AR195
Havent ran it yet. I am using 5200 Black.
jEt_jAk
SoCal
AR195
Had it on the lake yesterday. Definite improvement as after I did a ribbon delete cavatation came back at full throttle. Now it is gone again. Top speed unchanged.
Georgetown, IN
@2kwik4u Any special considerations when removing and replacing the intake grate?
Nope. I just unscrewed mine. Removed and set aside. Did the things. Then, threw some sealant on it, and screwed it back in. No idea if that's right, but that's what I did.
@swatski might know the official procedure.
That sounds about right. Can't find it now but there is a long thread on intake grates, modified by gmtech. I tried the same, thinning them out for better water flow, but they tend to break, so now I have new unmodified intake grates installed.
Anywhere where air can be sucked into the intake tunnel from the bilge - needs sealed. When the intake grates are out, it's easier to inspect for those leak points around the intake tunnel.
jimbobalu
Eden Prairie, MN
So no through hull bolts with nuts on the inside? I read in another thread someone had this. Any threadlocker on the bolts or just sealant?
No, no nuts on the inside, that's with scarab/rotax jet boats.
I would not use thread locker.
I think I used sealant around the seams, not sure if it matters. I definitely matters inside the tunnel.
Strat
Just wanted to send out a big thank you to Swatski, et al, who suggested this "mod". I did not expect much, but took off the intake grate for the first time (I've owned my AR190 for 3 years - 2018 model), scraped off the sealant that was sticking out and added sealant where there were gaps. It wasn't pretty, but like I said, I didn't expect much. I was wrong. Immediately noticed a difference in sharp turns. It would previously feel like it was cavetating, but has virtually stopped that. Sounds a lot better too. Just seems to run smoother. Anyway...thank you! Great suggestion.
Top Bottom
