mrcleanr6
- new jersey
- 275SD
First do the zep purple industrial degreaser then do the acid mix you used on the hull.
I applied the degreaser, it didn’t do much with the gunk.First do the zep purple industrial degreaser then do the acid mix you used on the hull.
Ok I’ll do a more liberal (big spraydown) application tomorrow. Cleaning boats is a young man’s game….well the degreaser is sodium hydroxide. basically oven cleaner. you put that on first because that will dissolve anything organic. it needs to sit and if its heavy it helps to use a scrub brush. it wil remove the slime, algae and anything like that. the acid applied afterward will then eventually eat away the corrosion.
Nice! Just curious if that's Lake water or salt?Here are a couple of pics, coming out of the lake after 3 months on the slip and following a good cleaning with Star-Brite Hull Cleaner. Just don't inhale this stuff! I use my boat brush to ease off the scum, comes brite white.View attachment 164234View attachment 164235
Fresh lake water, when I was on Lake Champlain , since COVID and the restricted border crossing situation I keep it on a slip on La Riviere St- Maurice (fresh water) here in Quebec, Canada, now it comes out brown because the water is rich in iron hence the brown scum , comes off just as well with Star-Brite Hull Cleaner.Nice! Just curious if that's Lake water or salt?
That’s 3 months??? My boat looked like that after 2-3 straight weeks of being wet slipped last season on our river.Here are a couple of pics, coming out of the lake after 3 months on the slip and following a good cleaning with Star-Brite Hull Cleaner. Just don't inhale this stuff! I use my boat brush to ease off the scum, comes brite white.View attachment 164234View attachment 164235
I went with simple car wash and a brush at the gunk on that transom plate. I didn’t have the guts to go with the Zep degreaser as @mrcleanr6 mentioned on those parts. You could spray and let that sit then go for pressure wash to clean it up. Then finish off with the Zep toilet and the HCL mix.Power washing did clean up most of it. What’s the best way to restore color and remove spots?
Thanks. Will try that.Your pissin in the wind with vinegar lol. Use the acid mix or keep soakin it with the zep industrial degreaser. Both are reactive with aluminum and if left for awhile it will eat all that stuff away
