I made a boat stand
dgfreeze
Central Ohio
I don’t recall seeing where anyone else has ventured to make a boat stand. Courtesy of the previous owner, I’ve got a ton of scratches, gouges, and dock rash that I want to get fixed, and I got sick and tired of dealing with the trailer always in the way, especially for repairs on the bottom. I got some 3/4” (**EDIT** I used 1", not 3/4") ACME thread, T handle nuts, and got to welding. The main frames are 2.5” X 2.5” X 3/16” square tubing. The crossmember is 2” X 2” X 1/4” square tubing. Gussets are 10GA. The steel plates I’m using to spread the load are 3/8” (**EDIT** 1/2", not 3/8") thick, with a couple pieces of 1/4” plywood between it and the gelcoat. Really isn’t hard, and while I haven’t worked on the boat since getting her in the air, I know it’s going to be well worth it. It’s a little crude, I know, but I just wanted something functional for once a year (if that). Forgive the messiness, I need two or three barns to keep all my crap.
HangOutdoors
Royal Oak, MI
That is a must have!!
dgfreeze
Central Ohio
Very nice. How do you transfer from the trailer to the stand and back?
Floor jack or bottle jack and a jack stand. Roll trailer forward until a crossmember or axle hits it, put the other stand/jack just behind the axle, Roll forward, reinstall first jack, and again roll forward Until a crossmember/axle hits it... takes a little time, but I did it alone in less than half an hour. Just take your time, and be deliberate. Make SURE your jack/jack stand is centered under the keel.
dgfreeze
Central Ohio
Not complicated, just a couple hours of cutting/welding, the ACME stuff, a bunch of steel. Well worth it, in my opinion. I’ve been working on the gelcoat all afternoon, and while I’m not enjoying it, it’s a world better than dealing with the trailer down there.
HangOutdoors
Royal Oak, MI
Great please send link so i can order one from you, and venmo, paypal or wiring instructions 😀
dgfreeze
Central Ohio
LOL, u wanna pay shipping for this thing?! 😂 I’ll gladly post a parts list, and you can just have a steel fabrication shop local to you weld it together. One catch is the crossmember of the frame, and the height of the uprights. I designed it for my boat. Other boats might require different lengths.
HangOutdoors
Royal Oak, MI
Bro you are in ohio, i am just north of you i can pick up :p ;)
dgfreeze
Central Ohio
Hey, if you’re serious, drop me a PM, and I’ll get some pricing together on Monday. Happy to make more, no sweat.
Canuckjetboater
SX195
I don’t recall seeing where anyone else has ventured to make a boat stand. Courtesy of the previous owner, I’ve got a ton of scratches, gouges, and dock rash that I want to get fixed, and I got sick and tired of dealing with the trailer always in the way, especially for repairs on the bottom. I got some 3/4” ACME thread, T handle nuts, and got to welding. The main frames are 2.5” X 2.5” X 3/16” square tubing. The crossmember is 2” X 2” X 1/4” square tubing. Gussets are 10GA. The steel plates I’m using to spread the load are 3/8” thick, with a couple pieces of 1/4” plywood between it and the gelcoat. Really isn’t hard, and while I haven’t worked on the boat since getting her in the air, I know it’s going to be well worth it. It’s a little crude, I know, but I just wanted something functional for once a year (if that). Forgive the messiness, I need two or three barns to keep all my crap.
@dgfreeze .....five words: brilliant, patent it, retire early. :cool:
dgfreeze
Central Ohio
😂🤣😂 I doubt it’s quite THAT brilliant, and it’s definitely quite simple to make. I’ll post the dimensions later this eve, so others can copy it. I work in a steel fabrication shop, so I just slapped it together after hours.
Yambers
Indianapolis, IN
He said humbly....
ChrisM
Rock HIll, SC 29730
Chaparral
VR
I'll take one for my,,,Ummm,,,,cough,,,cough,,,Chaparral.
I've been wanting to get it off of the trailer for adjustments, and do a polish on the full underside. I would probably substitute the plywood landing pieces for thick rubber ones.
HangOutdoors
Royal Oak, MI
Does it come in Royal Blue
dgfreeze
Central Ohio
Blasphemy! 😂 Lol, I’d be happy to build one for anybody, but the dimensions very well might be different. And shipping would be a killer. Just take the pics, measure up your boat, and have a local fab shop make one for you. I’ll be making a sketch later tonight with some rough dimensions, and explain some of the reasons I did things one way, and at the same time, some thoughts I’d have to do it differently.
dgfreeze
Central Ohio
haknslash
Lake Martin, AL
Moomba
Look at the beautiful aged gasoline jug without the stupid EPA autoclose spout. Good ole days!
dgfreeze
Central Ohio
We sell “water spouts” that may or may not fit conventional gasoline jugs... if that spout ever spits the bit, I’ll have another free flow on there. I’ve never spilled more gas than when I use those stupid EPA jugs. Useless.
haknslash
Lake Martin, AL
Moomba
yes those things do nothing but cause spills and frustration especially the ones with the nozzle shutoff!
Mine pours like a BOSS though ...even with its shutoff to meet stupid EPA regs :D
