Scottie
- Helena, Alabama
- X
So I've developed an issue with the port side impeller. I thought I had something stuck, but wasn't able to find anything. I decided to pull the impeller, and I haven't been able to actually remove the impeller yet, just can't get it to slide out. On inspection, I don't think there's anything in there. There are some metal shavings, and I believe the impeller is contacting the wear ring. At idle, it seems to run smooth, but at 4000 rpms or above there's a definite bump, and metal to metal sound/feel. It is not seized, and it seems it will run as fast as I want it too, though obviously there's a big issue. So what's going on here? It seems a bent impeller would hit the same place all the time. Am I losing a bearing? Would else could it be? How do I check?
