MrMoose
- Calgary, AB, Canada
I would love to see this.They had to fill the void with fiber glass.
Yes, you've missed the point. Seriously. Look at the pics. It's not the spacing between the outer hull and inner shell that is changing significantly, one has hard filler between the two surfaces, the other has none!!!!!!!!!! ^#$%^#$@%^%ck!!!!!!!! The factory fucked up and omitted the solid/structural fill on some boats, and in my opinion, that's a problem that Yamaha should fix.
So far one dealership has appropriately diagnosed and corrected the problem. Use that as precedent if you see that you have a problem once you pop out your drain fitting to inspect that space.
@micj's dealer recognizes that you need something solid in the space between the outer hull and inner shell, so they filled it with fiberglass before reinstalling the drain fitting.
OMFG, you guys are killing me!
@MrMoose this is beautiful. I edited my posts above to better fit with your schematic - great resource!
I cleaned up the old fitting and used a piece of tubing to help keep the 3M5200 from plugging up the drain hole. I'll yank the tubing out tomorrow morning once the 5200 has firmed up.@MrMoose this is beautiful. I edited my posts above to better fit with your schematic - great resource!
Maybe you would be wiling to also move your tube insert trick here, or link to it.
Thank you. Very useful schematic.
Yep, this is exactly what has been reported, starting last year. Here is a pretty comprehensive report from @Reefdonkey: https://jetboaters.net/threads/new-ar210-leaking.12003/. Seems like he has had a very similar amount of damage. Good news is - it is a easy fix, and it all dries up (it is a boat after all), but it's a shame you would have deal with this with a new purchase.micj were you getting water in the boat like this...
