MrMoose
- Calgary, AB, Canada
Edited on 05/08/2017 to correct my misconception in one of the photos:
At this point in time, I think that it’s necessary summarize the anchor locker drain problem in a new thread because I think that it will help others take appropriate action to correct it if they are affected.
If you have a FSH or a current model 21 footer, you need to read this whole post because there is something that you need to be aware of.
So far we know that all current model 24 footers, 21 footers, and the FSH are affected. Most 24 footers are affected to a lesser degree than the FSH and 21 footers. @Julian has mentioned that Yamaha knows about the problem, and that it will be corrected on new production.
The problem is that the anchor locker drain fitting is too short to properly seal to the inner shell of the anchor locker. The following pic is from the anchor locker of a newly arrived 242X in a dealership lot in March/April timeframe of 2017:
If the spacing between the outer hull and the inner surface of the anchor locker shell is significantly greater than the length of the drain fitting, the resulting gap will allow water to flow in between the hull and the shell (2017 21 foot LS):
The FSH, 24 footers, and 21 footers all use the same part number for the anchor locker drain fitting. On the 24 footers, the fitting is often about 1/16"-1/8" short. On some but not all of the FSH and the 21 footers, it's often much shorter, which creates the gap and allows the water to flow into the bilge rather than out through the drain.
As far as I’m aware, this problem does not apply to older model hulls, just current model hulls.
I hope that this helps.
