Installing Lumitec Underwater Lights
Haycor
Toronto
212X
Hi. I will be installing the underwater lights on the back of my 2015 212x over the next few days. If anyone has any advice on running the wires to the transom that would be great. Planning to install a small push button switch in front of the throttles to control them, as well as the new docking lights I'll install.
Thanks!
Jason
. I just installed the titan 2 rgb. The wires are not what you'd expect. This video explained it. I went thru the hatch between the jet plugs using some stuff romex wire to fish with. Then thru a hole in the engine compartment.
