mrcleanr6
- new jersey
- 275SD
im not sure how close you are to getting it to fit but if you pull the mat out from under it and it does not fit you can also flip the yeti over and pull out the 4 rubber feet. that will gain you another 3/8-1/2". a 45 yeti wont quite fit in the 275 cooler spot but if you remove the feet it just squeaks in with 1/8" to spare plus it slides in and out of the cabinet better. it may be similar in the 252
