Intermediate bearing housing
Stevenpigsooie
Beaver Lake, Arkansas
Is this a leak? I didn’t notice any problems last season and never had water in the engine compartment. Changing oil today and looked around and found this on both engines.
boudin
Lake Livingston, Texas
Looks like it might have been over greased? Did you add grease via the grease nipple?
The bearings are hermetically sealed and require no additional grease... ever. The grease in the housing only helps provides a water barrier inside the seals. If you are not seeing any water in the engine compartment, I would just wipe up the excess with a rag and then just run it.
-Greg
rsg1963
Dublin, Ca.
Yeah, looks like over greasing of the bearing housing surround. I usually give mine one or two pumps per year and that's it. No excess when I've done it.
swatski
Saint Louis, MO
This has happened in many boats, without any ill effects. In theory, could indicate a blown seal in the bearing housing (not the bearing seal itself) but the only role for that grease there is to keep water away - so if there are no leaks there is nothing to worry about.
MidnightRider
Oronoco, MN
I actually had a small amount drip out from factory even before I did my 10 hour, wiped it up and never saw anymore. Yours looks quite a bit worse, most likely from over fill but as others are saying, as long as there isn't any water, wipe it up and drive on.
rsg1963
Dublin, Ca.
May! LOL. Considering this was about leakage I suppose we were a little late to the game. :)
Cobra Jet Steering LLC
Vendor
Florida
It is best to leave those alone completely, if you over grease that you risk separating the rubber from the aluminum housing and then you will have a real issue, I have over 650 hours on mine and since I do not grease them I have yet to have an issue with them. You can remove the grease fitting and insert a piece of line trimmer string to take a sample of the grease and see if it is ok or has water, if it looks ok put the fitting back and don't mess with it.
Sebatussie
While on the sandbar, I realized there is s very small leak coming in by that same bearing. Do you guys know if that is hard fix? 2012 SX 240 , the leak is very little, (1 drop at a time).
Thank you !
Vendor
Florida
Once it leaks you need to replace it a s a p ,water is entering in your bearing , do both bearings at the same time . If one goes the other is going.
Sebatussie
Thank you for your response. Is this something easy to replace ? Or maybe tyhe question should be if this is something anyone can do or I bneed to take it to the dealer?
Vendor
Florida
Dealer or a mechanic that knows what he is doing .
Vendor
Florida
That sounds like a very good idea. I have done several and it's a lot of work.
