Jerlane
- Minneapolis, MN
Good to know! Now let's hope I never need to do it!
We’re pleased to announce an extra $100 off for JETBOATERS.NET members on any Ridesteady for Yamaha Speed Control system purchased through February 15, 2026.
Made one quite similar…. It works great.TR1s only weigh 160lbs... slide it forward 2 inches with pump already pulled so you can remove intermediate assembly. Hoses and wiring have enough slack built in. Other big help was platform plank over engines. Not pretty but it works. Lying on that allows you to use both arms and hands as you work vs using one arm for support.
loud rattle usually means bearings, loose bolts or misalignment. it could be the intermediate bearing. at 250 hours and 6 years old boat even in fresh water the bearing could be failing due to rust and wear. The other problem with vibration is that it could loosen the bolts that hold the bearing to the bulkhead and hopefully the alignment shims didn't fall off. If you are comfortable doing your own work on your boat first check there is no damage to the wear ring on the impeller. if damage replace. then check if there is any play on your driveshaft coupling, if so may as well remove and check the intermediate bearing and replace if necessary. let me know if there anyway that I can help. good luck.@Riveramx and @Cobra Jet Steering LLC and @FSH 210 Sport
Wow! This thread is incredibly helpful.
I have a 2019 212X and I’ve been chasing a “rattle” in the starboard drive that happens after we’ve been on the water and warmed her up a bit. She’s quiet when we leave the dock, but the rattle comes and goes while we’re idling or no waking after the engine has warmed up. I inspected the cone bearing and found no issue. I pulled and inspected the pump and found no wear marks or other issues. I tried running the engine on the hose without the pump. I didn’t hear the noise, but I’m not confident that I ran the engine long enough to warm the affected parts.
Nevertheless, the sound seems to me to be vibrating the back panel of the engine bay that the intermediate bearing bolts into. I’m thinking that I just need to run it longer on the hose, or maybe get it warmed on the water and quickly pull the pump and check again.
I’d like to be sure before I start into the intermediate shaft replacement.
Like you, I’m not confident that I got much grease into the housing for the first few years. I’m currently at about 250 hours (all freshwater.
Any thoughts?
I have the same thing - it's not your bearing, it's the external pump and steering components. With your boat out of the water, go back to your pump nozzles and jiggle them around - they are loose and clunky.I can’t say that the rattle is loud. It’s a little annoying and comes and goes for a few seconds at a time when idling. If I go to no wake speed, the noise goes away.
I’ve already checked the wear ring/impeller. No real issues there, but I see some faint signs of cavitation erosion on the impeller edges in a couple spots. I can’t imagine this making the low rpm rattle.
I have no water coming through the IDS Assembly and no water in the bilge.
Any thoughts?
Get a long bar or extension to place on different components that could be causing it and put the other side to your ear. Compare it to the port motor in the same spots. Even a bad bearing that isn't loud will be louder enough to hear it through the bar. I have a mechanics stethoscope to use but a metal bar, pipe, or anything long and metal will work.@Riveramx and @Cobra Jet Steering LLC and @FSH 210 Sport
Any thoughts?
So you removed the pump from the boat to run the engine??? Jet boats with stainless steel wear rings make a rattle and some more than others I would say check the motor mounts also to be sure the engine is not loose@Riveramx and @Cobra Jet Steering LLC and @FSH 210 Sport
Any thoughts?
Excellent!Get a long bar or extension to place on different components that could be causing it and put the other side to your ear. Compare it to the port motor in the same spots. Even a bad bearing that isn't loud will be louder enough to hear it through the bar. I have a mechanics stethoscope to use but a metal bar, pipe, or anything long and metal will work.
Also resting your hand on it might feel the vibration different from the other side but it isn't foolproof that way.
If you listen to both intermediate bearing housings with a stethoscope and both sound the same, i doubt its your issue. Even without temperature in it you would hear the difference even slightly it would sound very different. The rubber damper will not hide the vibration when listening with a stethoscope.Great responses! I’m going to group my follow up.
1. I don’t have any aftermarket steering devices. I tried grabbing the nozzle in the water while the noise was occurring to see if this would affect the noise. Didn’t seem to have any affect. I’ll try this again. The noise is coming from the starboard side which is attached to the articulated keel. I’m not sure if that would make it better or worse. Wondering if I should disconnect the keel and see if that affects the rattle.
2. Yes, I ran the motor on the hose with the pump pulled. No noise, but like I said I don’t have the noise during my idle out from the ramp. I’m wondering if the heated shaft is pushing the bearing to the side. I’m not confident that the shaft will heat up much running at idle on the hose.
3. It’s hard to be confident in the greasing process. I’m going to try the gear lube recommendation.
4. I have used mechanic’s stethoscope to listen to a variety of components: bearing housing (multiple locations), but i didn’t find anything roaring. I’m thinking that the rubber damper may also be damping any bearing vibration. I’ll spend some more time with this.
5. I will check the engine mounts. I have not done this, but I have put my hand on both valve covers (starboard and port). Didn’t seem like much difference, but I’ll double check.
while you are at it angle the boat down in the front if you have it on a trailer, remove the pump cone and use the plastic syringe DENTAL TYPY to inject 3 or 4 syringes of gear lube in the pump housing and then clan the cone seal O RING and reinstall the cone that will make the pump last a lot longer You may just have a bad spark plug or electrical connection causing the engine to have have a intermittent skip MISFIREGreat responses! I’m going to group my follow up.
Not necessarily, it depends on a few things, mainly how much grease gun puts out per pump, and how much grease is in the housing. If my boat had a remote greasing point I’d make sure that tubing is filled with fresh grease by removing it and pumping new grease through it until new grease comes out the end at the housing. Next check the housing with a piece of line from a weed wacker, if the housing is relatively empty you’ll need to add grease until it is fill up. I used an irrigation syringe to determine how much grease came out of my grease gun per pump so that I’d know how much I was adding.So... is 2-3 pumps per season from the zirt fitting connected to the hose still correct?
As displayed in the picture below. I thought the fitting was only for the bearing, but looks like it serves the bearing and the rear seal to prevent intrusion of water into the assembly. This has been the same assembly for more than 20 years as some of the wave runners from the early 2000s use the same part number.Not necessarily, it depends on a few things, mainly how much grease gun puts out per pump, and how much grease is in the housing. If my boat had a remote greasing point I’d make sure that tubing is filled with fresh grease by removing it and pumping new grease through it until new grease comes out the end at the housing. Next check the housing with a piece of line from a weed wacker, if the housing is relatively empty you’ll need to add grease until it is fill up. I used an irrigation syringe to determine how much grease came out of my grease gun per pump so that I’d know how much I was adding.
@madtom ‘s pics and descriptions of prepping the new housing for install was enlightening, when greasing the housing, if greased SLOWLY excess grease will come out on the water side of the intermediate bearing and not damage the seals.
@Riveramx thanks for making this thread ! It removes a lot of mystery about this subject in real pictures. The manual has this exploded view, but I’d never thought that the design would allow water to sit in that area behind the bearing holder, but I can also see the wisdom of that design, it allows the lovejoy connector on the intermediate shaft / bearing side to float while being suspended on an isolation bushing.
The two O rings, part #3 in the exploded view, do those go on the outside of the intermediate shaft, inside? Can you please explain what their purpose is? I think I can see them here.
My manual is specific about how much marine grease to add at the 10 hour mark, I think it’s 33 or 35 CC’s, then a very small amount every 100 hours or annually. What is obvious is that this bearing needs lubrication, this bearing spins at whatever rpm the engine is turning, at WOT that’s 7500-8000 rpm, at cruising speeds it’s around 6000 rpm plus or minus. Now I pull the zerk fitting out and use a piece of weed wacker line to check the amount of grease that’s in the housing at the maintenance intervals and add grease accordingly.
Did you grease the new bearing assembly before you installed it?
Very helpful info on how to move the engine forward to get enough room to R&R the bearing assembly.
Well done!
Hey FSH! Based on the diagram, which parts would you order? All of them? Do I really need to replace #17, #2, etc? Thank you@Riveramx thanks for making this thread ! It removes a lot of mystery about this subject in real pictures. The manual has this exploded view, but I’d never thought that the design would allow water to sit in that area behind the bearing holder, but I can also see the wisdom of that design, it allows the lovejoy connector on the intermediate shaft / bearing side to float while being suspended on an isolation bushing.
Well done!
