Brian Filas
- Richmond, VA
- FSH Deluxe
My dealer originally told me I needed an expensive custom adapter plate to be fabricated. After the fabricator failed to show on three occasions, another service manager looked at it and determined it didnt need it. Here is their installation which seems to work fine. The last photo shows the plug location.I just bought a 2016 Fsh Deluxe. It is back at the dealership so they could install a new minn kota 24v 80lb thrust ipilot trolling motor. I want it to be mounted to a quick disconnect plate so that it can be removed for water sports. Apparently the Fsh 190 has a bow that is not mount friendly for the saltwater series ipilot due to clearance issues. The dealer is trying to get an adapter plate fab up in order to mount the trolling motor with all 6 bolts. Minn kota said they have been mounting with only 3 bolts allowing the motor to hang off the bow more for clearance. Any help here? I don't want my new ipilot to rip the bolts thru the rail of my new boat due to improper mounting. Any help here?
This is a 36 volt 72" shaft. All three dedicated batteries, and minkota 3 bank charger in change compartment towards the bow so change floor still wide open.My dealer originally told me I needed an expensive custom adapter plate to be fabricated. After the fabricator failed to show on three occasions, another service manager looked at it and determined it didnt need it. Here is their installation which seems to work fine. The last photo shows the plug location.
Here you go...
I already had the Minn-Kota RTA-17 quick mount from the old boat.
For this new boat, I purchased an 8" x 24" piece of 1" thick Starboard and fabricated that base plate in the photo and mounted the "boat side" puck from the RTA17 to it.
It may seem a little long but I wanted to try and get the I-pilot as close to the boat center line as practical. The FSH doesn't have the best bow shape to easily make that happen so you will need to have some bow overhang on that mount. Only my recommendation but...the FSH isn't the best "tracking" boat in the world so you'll want to try and sneak as close to the center line as you're able. If you're going to do a lot of trolling, you'll be happy you did.
You can keep sliding things around until you're happy with the position and then mark your holes and drill away. I was easily able to catch four holes in the base plate which keeps mine nice and secure. I just spent a couple weeks down in Florida on Choctawhatchee Bay and out in the Gulf with not a lot of smooth water during our stay...it did very well.
This is the only photo I have here on my cell phone, I could take and post some better ones later tonight perhaps if needed.
Just get the factory mount..
Super late post, but decided to reply just in case anyone new was reading the thread. Made a custom aluminum mount ($250 at local machine shop). Has 7 anchor points, because I pushed it pretty far out so I could get as close to the center line as possible (and still use the anchor locker). It is solid as a rock.
View attachment 47983View attachment 47984
Brian, any chance you could share the template of that mounting bracket? I have a 2017 FSH. Want to get the Minn Kota Ulterra, but the dealer tells me it will bang up against the boat during deployment. This looks like it would solve my problem. Thanks Brian. Nice job!Super late post, but decided to reply just in case anyone new was reading the thread. Made a custom aluminum mount ($250 at local machine shop). Has 7 anchor points, because I pushed it pretty far out so I could get as close to the center line as possible (and still use the anchor locker). It is solid as a rock.
