Pinhacker71
- Verona, KY
- 242 Limited E-Series
I placed some foam squares inside the gas tank compartment covering the back wall of the hatch and the top surface to see if it would help with sound deadening. Will this cause a problem of any kind? I assume there shouldn't be a heat issue, and venting occurs outside the hatch through the vent line. Is filling this space with foam going to cause any problems? Thanks. Matt
