Jp207
- Gorham, Maine
- SX
My damn ADHD still gets me! I need pictures not words!
Is buying two single engine units for a twin engine boat over kill was this tested at all? I'm guessing the reason for two models was to keep a certain price point. Just curious if the difference of doing this would be significantly noticeable to justify the additional cost?
I would think based on the videos provided that 2 single engine units installed would not provide a significant enough benefit since when hard over you will always have the lateral thrust of 1 unit hitting the other nozzle. In fact, it may have adverse effects as it bounces off the other nozzle.
BRP's design would have the same flaw but they do it which would lead me to believe there maybe an advantage to it but I could be very wrong it definitely would not be the first time I was if so lol.
So once again I must agree with my devil dog friend! The brp design brings the reverse at less than ninety degree angles under the boat but also not complete zero degree angles as you can see with the bucket design. Jet boat pilots will increase lateral thrust as steering is turned harder in either direction. The lateral thrust is much closer to a right angle I believe. But once again feel free to correct me if I'm wrong!
I will draw my experience with the navy jet boats. The bucket was much closer to a brp design from what I can tell almost identical. Yamaha seems to be the outlier in that regard. So I guess I was agreeing with you @Robert Sands because I know that the bucket design for brp is almost identical to what we had in the navy. Just no where near as robust. But flow was the same.
Until they will offer us independent bucket and throttle controls the true potential of jet boats will not be reached.
