Jgorm
- San Diego / Colorado river
I got some 1/0 welding wire, and used some actual welding wire to feed some power. I can't believe the po used 8g.
Hydraulic crimpers are the only way past 4g.
I pulled off the crimp on the welding wire. The hammer crimps suck. I pull as hard as i can on every connector.
I've been in this thing too many times!
I use a bolt for the ground distribution.
300a cheap breaker. I hope it works! $14
Still gotta hook up the battery.
Mini anl fused distribution. Don't buy anl fuses, buy mini anl! Gotta return those and run the 4g to the amps. I'll have plenty of capacity to add another amp.
