- Naples Florida
- SX
I have a JL M6450 that will not turn on. There is 13V at the amp. The remote wire triggers 5V. Heres the wacky part, when the remote wire is activated the volts drop to 5.XX on the power feed.
Batteries passed a load test and the sub amp turns on just fine on same battery and same remote wire.
Bad amp? I had another identical amp and it does the same thing, thats why I am scratching my head! What are the chances 2 amps have the same issue?
@David Analog
@Earmark Marine --- got your website up and ready to order a new one if that is what I need
@David Analog
