Keep guard self installed. Touch up needed
Amar Nanduri
SeaDoo
Challenger
I just installed a keelguard on my friends boat. I noticed a fine half inch line of sanding and cleaning that I did when installing my the keelguard. How do I fix this ? Do I need a touch up paint ? Thanks.
Best
Amar.
jcyamaharider
Event Sponsor
Event Sponsor
Rosebud, Mo
Time to break out the buffer and polishing compound. Your boat is colored gel coat and not paint. You just need to polish. I am sure someone with some more expertise will chime in.
Neutron
New Bern, NC
You can tape off the keelguard and wetsand the scratched area with fine wetsand paper. Then polish after
jameskeller76
Georgetown, TX
Wait, you have to sand the gel coat to add the keel guard?
jameskeller76
Georgetown, TX
Yes it comes with a scotchbright pad to scuff up the surface
Got it, so it would be best to lay down tape to the proper width before scuffing.
Neutron
New Bern, NC
Amar Nanduri
SeaDoo
Challenger
Did that. Missed a couple of places especially where the bow curves and the masking tape went wide. Going to get some wet sand paper and see how it goes. Any specific brand or number I need for this ?
Neutron
New Bern, NC
800 to 1000 grit wet sandpaper should be good
Amar Nanduri
SeaDoo
Challenger
Neutron
New Bern, NC
It should. Just may take some more elbow grease. But that will definitely bring the shine back
Jaime
Best
Amar.
I was told by the dealer that is not color gel!!! That is automotive paint.
Amar Nanduri
SeaDoo
Challenger
I will know today when I wet sand and buff it out
jcyamaharider
Event Sponsor
Event Sponsor
Rosebud, Mo
Bennie
Loxley, AL
@txav8r
According to the instructions that come with the KeelGuard the reason for the scuffing is two part: (a) to provide a rough surface for a more permanent bond, and (b) to remove the "anti-microbial coating" that is on the outer layer of boats. (which deters a proper seal with the 3M adhesive)
Amar Nanduri
SeaDoo
Challenger
Yes. The lesson learnt here by me is...make sure to mask tape accurately first and double and triple check before I start scuffing to avoid headaches :banghead:down the road.
jameskeller76
Georgetown, TX
@txav8r
Good to know. A lot more work than I anticipated.
Amar Nanduri
SeaDoo
Challenger
3 hours from start to finish for me
