EricE
- Pennellville, NY
- 212S
I don't have my boat yet, but I might be in if the price is right.
There are several threads on this, here is what we came up with (the install details are in the post 85, I think, of that thread):does anyone have pics of an install?
We are working off of the Lectrotab design of @Bruce and Dan Roberts of Linear Devices Corp (parent company making Lectrotabs). The standard tab dimensions in that kit are 12"x12" (chord x span), 14" actuator, and the attachment point is at 7.75" from the hinge/hull.
Those work really well for boat attitude adjustments, or as regular trim tabs. However, there are several issues with the above tabs/actuators if used as wake tabs, the way I see it. Most notably, those overall dimensions would NOT be compatible and potentially interfere with other wake shaping devices. For example, Gantlin Wake Wedge install would NOT be possible. Or other devices, such as an adjustable ASP-like platform (AKA Swatski's Tail, LOL), etc.
Shortening the actuators, the ONLY readily available solution, would dramatically reduce the tabs' range of motion due to the reduced stroke of the "short" actuator, 2.25" standard vs 1.5" "short". The only way to compensate for that is to move the attachment point closer to the hinge/hull, which would also weaken the load rating, which needs to be compensated for with the shorter chord (but longer span to retain the surface..). Etc, etc.
So, long and short, here are some considerations and solutions we came up with.
SPAN
The general recommendation is using tabs that are 9 inches in chord (distance from transom to trailing edge of the tab) the tabs should be one inch in span (width port to starboard) for each foot of boat. Accordingly, tabs for my boat should be 24" x 9".
The largest span of the tab that can be easily fitted is 16" (again, that is the width, or port to stbd measurement).
Making the tabs 16" x 9" would do the trick, close enough to 216 square inches to make a noticeable difference in lift without placing undue stress on the system. 16x9 is also the same surface as 12x12 that works extremely well in the above mentioned 23/24' Yamaha boats.
Importantly, 16" is also the largest span to fit exactly flush with the transom (in my 2016 240).
TABS PLACEMENT
On boats powered by outboards or sterndrives it is necessary the trim tabs not be placed too close to the drive unit to avoid disturbing the water flow to the propeller thus causing ventilation. This is usually no closer than 7”. General rule is no less than 8" from the center of the drive. 16x9 tabs would fulfill those criteria, however that is probably an overkill anyway as the intakes in our jetboats are far removed and would not be obstructed with tabs. I have learned however to be conservative with any such estimates. That said, looking at the picture from @Williamsone46 (in an above post) - the tabs would be out of the water and out of the way of intakes FOR SURE at planning speeds. So, 16x9 tabs would work well here.
SHORT vs STANDARD ACTUATOR STROKE vs RANGE OF MOTION
This has been the trickiest item to tackle and plan around. Standard actuator has a stroke of 2.25" (fully extended) and affords approximately 16.6 degrees of tab movement, I think (see below). To determine how a switch to the short actuator (with a 1.5" stroke) affects the range, we did a little back-of-the-envelope calculation here (where a is the measurement between the hinge/transom and the actuator attachment point in the tab):
(this was drafted by my son, as we were driving and talking, he just whipped this up on his tablet)
Basically (some oversimplifications notwithstanding, such as ignoring the change in the actuator angle of attack - which should be fine as it only moves a total of <20% of its length, etc.):
The current standard actuator attached at 7.75" affords the range of motion of approximately 16.6 deg.
This would be mostly retained by using short actuator attached at 6" from the hinge/hull.
That is the final "best case" scenario we could came up with:
1. 16"x9" tabs
2. short 10" actuators with 1.5" stroke
3. 6" attachment point (in the center of the tab's span)
Additional considerations are a few. Taper would be initially bend up, but possible "drop fin" add-ons (AKA "DF12" in Bennett parts) would be considered, etc, all pending test results in the water. Chine overlap is not an issue with this design (I believe). Internal hull fiberglass enforcements of actuator attachments are strait forward, not discussed here.
Here is a rough sketch of tabs' placement:
(Short actuators' attachment points in the hull would not interfere w/ Wake Wedge mounting points / tie down eyes, and tabs would not interfere with fins)
The short answer is no. No one here has integrated those into anything, so only three flavors - manual, ("semi-auto") MLC-1, or auto ALC-1.So... while we are talking about this. Do they have way to integrate into a nmea2k network? I'm interested and would love to control vis my chartplotter
Just talked to Russ at Lectrotab-The deal is brewing and it's starting to look sweet!
They will probably do the usual Jetboater's group buy deal.
The more committed buyers, the greater the discount up to the maximum that make business sense for them.
They are working it out now and will probably be able to announce a deal Monday or early next week.
They will probably set a standard price on the configuration I mentioned above with adders for the ALC-1 and any different tab configurations.
Russ said the 9 x 16 Tabs and the short actuators (28' cable) will fit the majority of the Yamaha models and years, which agrees with what I have been reading in the Forum.
So, please show Lectrotab, how many of us want this deal and respond to this thread!
Thanks Everyone-I'm already drilling my tab mounting holes! (just kidding)
For all you "long affiliated" members, group buys are a routine procedure evolved from the not to be named out loud "other forum". So, bare with me as I try to explain.How will we know when and how we can purchase
OK, this is the deal from Lectrotab
The kit we identified as the base unit that will be sold thru this program, will contain the following:
2) S-BK-24, short, 12VDC actuators w/28’ cable
2) T9x16-9282, stainless steel tabs, w/taper bent sides (up)
1) MLC-1, manual leveling control
These kits are typical for all of the Yamaha, 240 & 242 models.
Here are the price ranges we’re offering. (The list price of these components $1,306.00)
1: $786.00 (standard, single kit discount)
2-10: $698.00
11-20: $653.00
21-30: $598.00
