- Lake Ray Roberts, Texas
- Boatless
- NA
- Other
- NA
The 240 has more cup holders @Bruce .
@robert843 , if I recall, it took 14" to cover the circumference of the sidewall of the cup holder above the bottom recess. You don't have to fill it, but you can only cut the strip ever 3 LED's, and that is between 1.5-2". Depending on whether your using 5050's or 3528's. There are new chips out now too and I don't know their spacing. I can't remember how many cup holders, trying to count them in my head. Let's say 10. That's 140" or 11.66'. Allow for messing one or two up. So your right on the edge of you just do cup holders, and don't do more than 10, with a couple of feet to add here or there. But if you do under the swim deck seat backs, you will use about 18" on each. You could do only 1', but you may run short if you break a couple, but you should be good. Disclaimer...I don't remember the exact measurement of he cup holder inside circumference but it shocked me! And 14" sticks in my head. But measure!, allow for cutting, allow for a nice radius on the strain relieved wire, and put some additional insulation where it passes thru the cup holder sidewall.
