haknslash
- Lake Martin, AL
- Moomba
- Other
Since my home AC died on me last night I'm stuck working from home today, so I figured I might as well start installing my new SeaDek kit from the jetboatpilot Group Buy. Loving the bow kit as I usually boat solo so I get on and off the boat from the front while at the ramp. This should make life easier and safer from slipping off or scratching my gel coat. Next up is the cockpit kit!
BTW this stuff smells great lol
BTW it's important to note that it would be very easy to accidentally install the two outer bow kit pieces on the wrong side and in the wrong orientation. You should place the mats so that the outer sides have the rounded corners and the inner sides should have the sharp corners. I've seen some people accidentally install these on the wrong side and rotated 90° from what they should be. Use this image below to help illustrate the correct orientation...
