Krzysiek
- Selden, NY
- SX
This is my first attempt to lube the pump bearing and I do not know how to do it right way. Your input is highly appreciated. The hose is very soft. It looks like there is no lube inside. Should I fill it up with lube so it is firm from the top to bottom? Should I also disconnect the bottom part from the housing and then connect again when I am done with lube? Should the hose be firm and hard to bend? Thanks!
