Lumitec Seablaze X on an AR240
Bill D
Prairieville, LA
It has it's own feed from the house bank. It is run through a fuse, then a switch at the helm, then to the controller. I'm not sure what the current draw will be for your setup, but this monster draws almost 5 amps.
I like being able to have the stern light on without the LED.
Trevor Shipman
Charlotte, NC
image.jpeg image.jpeg image.jpeg image.jpeg Well I finally knocked it out. Went with 3/4 King Star board. Used a 4-1/4 hole cutter then sanded and buffed the sides to pollish it up. Took a bit of sanding to get the curvature but none the less super excited about the turnout. Put 5200 between everything just need to see how she looks in the water. After testing I can't imagine needing a middle light but we'll see
Mark
@Trevor Shipman that looks awesome! Very clean! I hope it works exactly like you want. :winkingthumbsup"
Trevor Shipman
Charlotte, NC
Thanks @Mark I'm really pleased with the outcome! I appreciate everyone's advise! Can't wait to get her in the water
Mark
Anytime! And I'm ready to make a few splashes myself!
shane hric
Hobart Indiana
View attachment 35162 View attachment 35161 View attachment 35159 View attachment 35160 Well I finally knocked it out. Went with 3/4 King Star board. Used a 4-1/4 hole cutter then sanded and buffed the sides to posit it up. Took a bit of sanding to get he curvature but none the less super excited about the turnout. Put 5200 between everything just need to see how she looks in the water. After testing I can't imagine needing a middle light but we'll see
Awesome job! I am installing my 3 when my boat is back from the awning shop (having my camping cover made). Is the King Starboard dense plastic? How is the cycling going between the blue and white fading or the strobing effects look?
Thanks
Trevor Shipman
Charlotte, NC
Thanks @shane hric the Starboard is very dense, nice stuff. I went with the 3/4 but you could probably get away with 1/2. I actually got the blue only, not with the white option. Good luck on your install, let us know how it turns out.
BigN8
Corinth, TX
If they are out of the water when you are cruising then you won't be able to use them when in motion. My buddy had his mounted a little to high and I was behind him going across the lake last year, his lights nearly blinded me. I could not follow him at all. After we told him he no longer uses them when he is underway.
Bill D
Prairieville, LA
Nice install @Trevor Shipman ! I can't wait to see them in the water.
FWIW, I usually don't use mine as much underway as when swimming behind the boat.
