Tobes
- Las Vegas
- AR195
I can lean it forward more which I will adjust over the winter. I was worried about clearances of getting it in the garage and where it would be sitting. It'll be fine so It will shift down a bit.I’m pretty sure I’m in, just priced out replacing the parts I need from factory and it makes more sense to just replace the tower... pretty sad, they want 70$ just for the threaded knobs...
Tobes why did you decide to mount up top? Would there be any reason you could think I wouldn’t be able to mount from the side? From the pics I’ve been looking at it looks like you can get a better angle / more forward lean if you mount to the side of the boat...
And as always thank you guys for your time and effort to get this going.
I used the factory mount for the front and drilled new rear holes (utilized the front factory holes for wiring, they are only 3/8" or so). Much stronger mounting than side mounting and I only had to reinforce 1 of the holes instead of 2 each side. Made it a pretty easy install coming from the factory tower.
