Mooring cover with out poles!
0627Devildog
Classifieds Moderator
Acworth, G.A.
Are you requesting a picture? Boats with a front facing tower can probably get away with two. They are 39.99 at boats.net. I don't think it was worth it but I have it set up now.
Just more info, never heard of it.
Correct!
Two sets work great in my 2016 AR240. In fact, the system works amazing - after half a season of heavy use. I would never go without a system like it in the future.
When on a lift, or wet slip, I start by hanging up the two hangtytes cords over the tow point (both w/pre-set length), and then just drape the cover over the bow and proceed backward, exit from the swim deck and zip-up/ratchet the cover. Done!
Worth every penny.
seanmclean
Medford, NJ
Hangtyte is definitely worth every penny. In fact, I'd probably spend twice as much if I had to, now that I have it. I can have the cover on by myself in the slip in 3-4 minutes. The most time consuming part is just having to redo the dock lines.
Weeb
Denver NC 28037
+1
COtoFLsurf
Key Largo, FL
+1 on Hangtyte, don't have it on my Yamaha but had it on my previous wakeboats, easy to install, easy to use, effective, and yes I towed with it. Good stuff.
foozed
Black Mountain, NC
252SD
Anyone using hangtyte on a 25 series yet? 252sd specifically - wondering if I need 2 or 3 hangtytes.
BigAbe75
Litchfield, IL
What does the tower look like? I would say just 2... one for the bow and one for the cabin. The transom area will probably slope on it's own pretty good doesn't it? How many poles did the cover come with? Same number of HangTyte's as you have non-pooling poles would be my suggestion.
Love it on my 242.
d_coyne1984
Chanhassen, MN
If would say put one anywhere the factory has a support except the bow. I would keep the pole for that. There might be too much angle for a hang hangtyte to work there.
scbruet
Charlotte
252SE
My hangtyte just arrived. Can't wait to get them on this week and ditch the annoying poles. I only have 2 for the 25se right now, so hopefully thats enough. Will let you know if I see any issues.
BigAbe75
Litchfield, IL
It’s nerve wracking cutting a hole in an $800 cover, but I’m glad we did it. We also used some anti-fray gel from the wife’s sewing kit in the areas we cut.
Georgetown, IN
Can you tow with the Hangtyte system in place? I feel like this has been asked and answered, but I can't find it with a search. I have having to pull the cover off, get in the boat, and put the poles in place under the cover, then climb back out and "reseal" the cover after towing. Would be nice to be able to tighten/loosen these from the side of the boat after a tow, or when towing in the rain.
Any thoughts from owners?
scbruet
Charlotte
252SE
Haha yeah for sure. My wife is handy with that stuff, so she's going to do the cutting. Good call on the anti-fray gel. I will use that.
seanmclean
Medford, NJ
I generally tow uncovered, but have towed with the cover on and hangtyte in place probably 10-12 times, it's fine from my perspective. No extra wear.
BigAbe75
Litchfield, IL
I agree. Towed 2 times with it on this year. 5-6 hours round trip both times. First trip I had a tube in the bow to support the cover. I loosen both front and rear cables as much as I can. 2nd trip, I didn’t use the tube. Kind of wish I had, just because I don’t like how it looks so sucked down (I was previously a poles up guy)… but the cover / hangtyte doesn’t seem to have cared one way or the other.
HangOutdoors
Royal Oak, MI
Oversized beach balls front and back works great with mooring covers.
BigAbe75
Litchfield, IL
HangOutdoors
Royal Oak, MI
Amazon.com : Giant Beach Ball
There are 36, 42, 48 and 6'. I got the idea from some threads here on the forum. I tried the 36" but unless I used two, one on each seat up front it seemed low, so I went to the 48" right in the center. Works great. But when you uncover in the staging area and there is a wind you may have to go chase it in the lake from the boat.... Ask me how I know :)
Thought about using two 48" side by side and not inflating them totally, but never got around to it.
BigAbe75
Litchfield, IL
And you do the same in the rear too? I really haven’t been too concerned about the rear. I just hate seeing all that pressure in the front.
HangOutdoors
Royal Oak, MI
Yes I have. But just on super long trips.
