Beachbummer
- Houston TX
- SX
I noticed the YDS allow testing of spark only in combination with another cylinder, but it also allows dropping a single cylinder... So as a sanity check I need to ask...
Is the MR1 firing only once per 4 cycles, or does it fire more often? (Like twice)
I'm hunting what I think is an ignition problem keeping an engine from reaching full RPM, and I've tried quite a few things with no results (new plugs, coil swap, ecm swap)
I will be confirming done other things tomorrow, but I wondered if the cylinder pairs that test together in the YDS actually fire together or if each cylinder spark fires totally independent.
Thanks!
Thanks!
