My 255xd build, upgrades & audio.
jacoviii
Independence Mo
255XD
So I have done a bit of work and upgrading to our boat over the past 2yrs. Progress has been a bit slow due to not having it for 2mo of last season for warranty steering work.
1. Subwoofer mounting ring is hallow and makes a buzzing sound during certain frequency. So I removed it and poured flex seal into the cracks. Then to make sure the flex seal fills into all of the voids I put it into a vacuum chamber. The vacuum chamber was a milk crate inside a heavy duty trash bag. Then used a shop vac. Also did a 1/8" foam gasket on the mounting surface between the ring and the boat. And even found a spot where the basket of the subwoofer interfered with tapered part of the ring so it got foam gasket too.
2. Replaced stock air boxes with cone style air filters. Mainly to make room for #3.
3. Relocation of house batteries to the starboard engine airbox area. My start and house, consist of four 6v 240 amp hour batteries. A custom battery tray was made for this.
4. Intake manifold ribbon deletes from Aqua sports performance.
5. Adjustable pump cones from Aqua sports performance.
6. Fizzle blow off valves.
7. Oil separators Mishimoto knockoffs Amazon
8. Three 10" subwoofer in the rear clean out compartment. Soon to be ported/ venting the clean out compartment to just behind the lower swim deck back rest cushions.
9. Transom RGB light's. No one had what I wanted so I made my own. The center is three 50w led cob chips the port and starboard are two 50w. I have only mounted the center due to working on trim tab mounts. The center is plenty bright but I want to be over the top.
F.M.
Decatur, AL
255XD
View attachment 202271 View attachment 202272
View attachment 202273View attachment 202274
View attachment 202277View attachment 202278
View attachment 202280View attachment 202281View attachment 202282
Happen to have a part number off that Spectre air filter that I can use for size reference?
jacoviii
Independence Mo
255XD
Spectre Universal Clamp-On Air Filter: High Performance, Washable Filter: Round Tapered; 3 in (76 mm) Flange ID; 6.5 in (165 mm) Height; 6 in (152 mm) Base; 4.75 in (121 mm) Top, SPE-9136
F.M.
Decatur, AL
255XD
Thanks
jacoviii
Independence Mo
255XD
On the list for this year is
  1. Lowrance HDS9 live have to make a bracket to slide the 12" conext sreen 2" to the left. Have to remove phone holder and make backet for the HDS9 and, a custom stern mount for the transducer.
  2. Zipwake 300mm install and wedge mount for the controller next to the Conext rotary control knob.
  3. SUBs... Need to move the three 12" Wet Sounds to their new location and add one more for a total of four.
  4. Make the manual wake booster harness. So that RPMs are not limited while fully ballast when surfing.
  5. Explore larger intercooler options.
  6. MapX tune
  7. Impeller options.
