MMWalton1119
- Lakeland, FL
- FSH
I have looked at the Magma grills and just can't justify spending Over $400 for a smaller grill and mount than what I have been using on the table top. I have an old Walmart grill that cost me $25 that I bungee onto the table. I get a lot of compliments about it. Even though it is gas it takes a little longer to get going. I want something I can throw a steak on and have it ready in just a few minutes. The Magma grills are too small for the price and even smaller than my Walmart grill. so I decided to try mounting the small portable grills from Sams Club. Here's my solution...
First my old Setup...
Now my current Grill.
With 2 huge Ribeyes and 4 Ears of corn. Grilling steaks is just like at home now.
And now I can use my table to prep everything
I bought the Grill from Sams Club for $99 and it has two burners for 20,000 btu's which heats up real fast plus it has more grilling space. I wanted to do away with using the green throw aways (I know you can refill them but that is also problematic). I bought a 5lb refillable prepurged Propane tank from Amazon. You should have seen the guy's face when I asked him to fill it. He'd never heard of a Propane tank that size that was refillable. The Grill has built in fold out legs but for my build they aren't very practical. I found 4 Stainless 4" inch legs at Home Depot for about $4.50 each and mounted them under the grill. Home Depot didn't have the black Chair tips, I found those at Lowes for $5. I first tried using 2 Walmart cutting boards for the stand but they warped under the weight. I ended up buying a piece of Star Board from Home Depot ($55) and cut 2 pieces to double up on the mount which worked perfectly. I bought the Magma grill mount from Amazon for around $65. I bought a 2 Pack of Stainless Rod Holders from Amazon as well for $20. Clear Castor cups for the legs to sit into without moving I found at Lowes. I screwed and 5200'd them to the Star Board mount. For safety I bought a locking paracord strap at Home Depot for $3.
This Pic shows the cutting boards (replaced with star board) but it shows the setup
Here's the stand with Star Board 5200'd together
The Stainless legs from Home Depot
And mounted to the Grill
Here's Everything I got except the the hooks and safety strap.
Grill - Member's Mark Portable Stainless Steel 2-Burner Gas Grill - Sam's Club
5lb Propane Tank - https://www.amazon.com/gp/product/B077BLDL7T/ref=ppx_yo_dt_b_asin_title_o06_s01?ie=UTF8&psc=1
Grill Mount - https://www.amazon.com/gp/product/B0018Y4T2W/ref=ppx_yo_dt_b_asin_title_o06_s00?ie=UTF8&psc=1
Rod Holders Flush Mount - https://www.amazon.com/gp/product/B06X9NLMNF/ref=ppx_yo_dt_b_asin_title_o06_s00?ie=UTF8&psc=1
4" Stainless Legs - Home Depot - Dolle Stainless Table Legs 4"
Starboard Equivalent - HDPE Sheet 1/2 inch 12" x 24"
Clear Castor Cups - https://www.lowes.com/pd/Waxman-4-Pack-1-13-16-in-Clear-Smooth-Caster-Cups/1000372639
Chair Tips - https://www.lowes.com/pd/Waxman-4-Pack-1-1-8-in-Black-Rubber-Tips/3032995
