itsdgm
- Rancho Santa Margarita, California
Well, it's a very long story of how this project began.
Two years ago I had a stuck valve in my 07 Yamaha AR210. That led to me pulling the engine at least three times and sending it back to the repair shop, almost missing an entire boating season, finally realizing that the hard to find water leak was a cracked block, then buying and installing a used replacment engine in the boat in order to save the next years boating season.
Well, what to do with the engine with a cracked block? I ended up finding a good used engine block pretty cheap which led me to swap all of the parts over from the original engine to the replacement block. At first, I figured I'd rebuild the original engine and reinstall it back into the boat. But how would I know if it was reliable? I know, I'll try to find a used waverunner with a blown motor.
Guess what? There's a reason why eBay is loaded with replacement engines and parts. These engines are way more durable than the hulls. Lots of guys simply part out the ski after major damage to the hull. So it took over 6 months of searching and finally I found a ski with a 2005 Yamaha VX110 Deluxe Waverunner with a Non-Ho 110 engine that was within driving distance.
So, will I make a profit on this deal? More than likely not. I probably will break even at best. However, I didn't feel like I could sell the engine if I didn't know how well it would run. Also, how would I know if my first ever engine teardown/rebuild was done right if I wasn't the one who first fired it up?
Also, I've had a very stressful last year. I really need a project like this to take my mind off of things. Wish me luck, here we go.
