MutherTucker
- Shelbyville, IL
To make a long story short. I bought this boat in June, went to change the plugs and oil and found fuel in the engine compartment near the exit of the fuel compartment plug. Pulled all the plugs, flushed the fuel compartment out, put it back in the water. No fuel was present for almost 2 months. I keep my boat in a slip with no lift. Recently, I checked the engine compartment and found a small amount of fuel again just outside of the fuel compartment.
I pulled the boat out of the water and took it to my "guy". I needed a new fuel sender anyway so I ordered one for him to replace. Once he removed the fuel sender he plugged up the hole and pressure tested the tank. He said it seems I have a pin size hole somewhere in my tank.
Now, purchasing a new tank is one thing, I can handle that part of it, but cutting a hole in the floor is an entirely different scenario. My "guy" is confident he can perform this task. I'm not sure where to go from here. I'm not sure taking it to the yamaha dealer is something I trust either and I am certain it will be expensive if I do.
Anyone ever had to replace a fuel tank before?
